0. Pavels 11.02.21 14:15
проблема — остановился во время печати с ошибкой CFB32.
попросил перезагрузиться.
после перезагрузки ошибка CFB31 и не работает
какие варианты решения, если кто-то сталкивался
показания счетчика могу уточнить
1. hp1012 11.02.21 16:01
<cite>4. CFB30, CFB31, CFB32 = Communication error between Main PCB and Panel PCB.
This error may show up when there is poor contact between the Panel DIMM and its socket, or failing to
upgrade the firmware. There was a case of defective Main Memory DIMM (SDRAM), so this might also be a
possible cause.
MEASURES:
- Check the contact between panel DIMM / socket. (Reseat DIMM)
- Upgrade the firmware or replace Panel DIMM. (Be sure to check FW combinations)
- Upgrade the firmware or replace Main DIMM. (Be sure to check FW combinations)
- Replace Main Memory DIMM (SDRAM). </cite>
Forward!, Go ahead!, Onwards!
