Panasonic kv-sl3066: код ошибки F65-57000000
0. MSBurdov 24.08.21 07:25
Всем привет подскажите что за проблема Panasonic kv-sl3066 код ошибки F65-57000000 из-за чего и как лечить???
1. kgbeast 24.08.21 08:04
Flatbed black level adjustment error
Problem with Pixel data from CIS (FB) or from image processing circuit.
1. Check the connection and soldering condition of the following parts.
(1) Between CN5 (CONTROL Board) to CN1001 (FLATBED RELAY Board)
(2) CN1004 (FLATBED RELAY Board) to CIS (FB)
2. Check the soldering condition of the following parts and of their surrounding circuits on the CONTROL Board and FLATBED RELAY Board.
(1) IC9 (PF4)
(2) IC3 (AFE)
(3) IC5 (D/A Conv.)
(4) R1000, R1001, R1002, L1000, L1001 (on FB Board)
3. Monitor the following CIS Timing signals on the CN5.
(1) CCLK_FB (CN1004-9th pin)
(2) BP_FB (CN1004-11th pin)
4. Replace faulty parts or boards
2. MSBurdov 24.08.21 09:20
спасибо буду разбираться!
