HP Laser MFP 137FNW: xMemory_initiate Faxdial 1196 JMT
0. kochevnickus 02.04.25 14:02
Была тут тема с данной проблемой, но перенесли её в архив. Автору было предложено подключится по дебаг и считать, но видимо автор пропал. Мной было считано.
====================== Check Boot [0x46495250]
First Boot... after exception occurred.
* System Information *
[tfKernelInitialize]
<<< Reelase Mode >>>
<<<LogMsg_PrintOff>>>[EPM] EPM_MainTask()
<<<HAL_InitWDT>>> WatchDog Initialized !!!
<<<LogMsg_EngPrintOff>>>
=============== ESCMS =================
[CTS Ver: M2070_4in1_Re_WR EP V2.3]
[CTS Ver: M2070_4in1_Re_WR FUSER V0.40]
[CTS Ver: Ratchet PRINT V2.0.181211]
[CTS Ver: M2070_4in1_Re_WR TR V2.2]
[CTS Ver: Ratchet COPY V2.0.1130]
[CTS Ver: Ratchet SCAN V2.0]
[CTS Ver: Egmont-N_3IN1 IEM V2.4.1129]
[CTS Ver: Egmont_N_F MARGIN V0.4]
[CTS Ver: Egmont_N_F PDIO v0.2]
Warning!!
Warning!!
[ConAdmin] Mem Alloc Size (204800), Avail (55424) in /home/printer/samba/workspace/BLD_REL_HP_M2070/Source/Subsystem/ConSS/App/ConIDS/IDS_Main.c 234 line
Subsytem [5] doesn't have Default Option for BB ID (1008) !!!!! kernel_main END!!!
J[2870][MemFaxTx][000][Idle ] Mc:..... I1:..... I2:..... I3:..... Fx:..... Ph:S....
Assertion failed
Task : JMT0
Cause : pstFJCB->stExtraNumInfo.pubDialMemPtr @(FJMFaxMemory_InitiateFaxDial, 1196)
------------------------------ Task JMT0 Stack ------------------------------
Text Start : 160000, Text End : f05f48
Stack Base : 1c66f38, Stack End : 1c69f33, Stack Current : 1c66f38
Start : 1c66f38
1 : 0x9b2025
2 : 0x1ad028
3 : 0x1ad0e8
4 : 0x1ad09c
5 : 0x2738e0
6 : 0x95e2b0
7 : 0x992612
8 : 0x967a84
9 : 0x992611
10 : 0xf05470
11 : 0xf05bf4
12 : 0x992611
13 : 0x16d440
14 : 0x9b1c85
15 : 0x16bba8
16 : 0x34998a
17 : 0x9f6d2e
18 : 0x9f7501
19 : 0x96e634
20 : 0x992237
21 : 0x96e690
22 : 0x1f8248
23 : 0x161014
24 : 0x992606
25 : 0x171e5c
26 : 0x992606
27 : 0x992606
28 : 0x2e05f1
29 : 0x25a1dc
30 : 0x224fa0
31 : 0x25b788
32 : 0x22a084
33 : 0x208a60
34 : 0x9d93f0
35 : 0x206ee0
36 : 0x206ef8
37 : 0x1a1b40
38 : 0x16dbb8
39 : 0x16bb64
End : 1c69f34
<<<Doassert_InformToPRN>>>
Func : FJMFaxMemory_InitiateFaxDial
Line : 1196
<<<Doassert_InformToUI>>>
<<<Doassert_InformToUI --- END>>>
MyDumpTaskInfo
Assert End!! Why?
<<<HAL_ResetMachine>>> WatchDog Reset !!! Sb6$ryp=~a2hd#sg[~a2`3uj~a28|(;!&)&#9618;
U&#9618;.2.&#9618;M&&#9618;0&#9618;&#9618;&#9618;a&#9618;V&#9618;2&#9618;&#9618;j0S)&#9618; j
N&#9618;r]&#9618;+&#733;&#9618;i&#9618;MX&#9618;K&#9618;:1 &#9618;&#9618;&#9618;B&#9618;&#9618;:1,j&#9618;&#9618;&#9618;&#9618;:SPIJ&#9618;&#9618;IAS'&#9618;27j&#9618; )
U&#9618;&#733;&#9618;dYV&#1393;сe&#741;&#9618;o&#9618;&#9618;&#9618;t*&#9618;d&#9618;7800&#9618;0R &#9618;&#9618;&#9618;e 0040&&#9618;&#9618;R
Board'&#9618;&#9618;m&#9618;&#9618;&#9618;aLM&#9618;_.&#9618;4
CC&#9618;&#9618;]Sb[&#9618;E&#9618;&#9618;3 &#9618;&#9618;]&#9618;8j
&#9618;HZ
&#9618;&#9618; ke^&#9618;&#9618; .&#9618;
&#9618;&#9618; &#9618;a]&#9618;K&#9618;ot R
&#9618;&#9618;&#9618;m&#9618;VQ&#9618;&#9618;e&#9618;: SR&#9618;"r-F SE : 0&#9618;0&#9618;&#9618;0,&#9618;x78f&#9618;&#9618;]]WW&#9618;
&#9618;&#9618;jaC&#9618;j:&#9618;Y.&#9618;&#9618;r :&#9618;r13 : QV&#9618;t&#9618;
&#9618;HU&#9618;&#9618;ker&#9618;&#9618; 0x001&#9618;0.&#9618;rj I&#9618;m&#9618;x&#9618;040000)J&#9618;&#9618;&#9618;e&#9618;r.&#9618;j)
&#9618;h&#9618;&#633;&#9618;&#9618; &#45393;e.&#9618;&#9618;&#9618; : r1&&#9618;EV&#9618;t 7--> Uart Initialize
--> InitCacheLib
--> StartMMU
--> EnableCache
--> Interrupt_Initialize
--> spgpMpIntDevInit
--> TxSetIntHandler
--> sysClkEnable
[WARNNING]Timer5 is not running? check it!!*
Now, tx_kernel_enter ...
==> tx_application_define[EPM] usrPwrMgrInit()
ExceptionCheckMessage
BackUp Debugging Message
Task Name: JMT0 , Exception Type: Assert
Assertion failed:
file FJMFaxMemory_InitiateFaxDial, line 1196
1. Polos 02.04.25 15:50
После чего начал так ругаться?
2. kochevnickus 02.04.25 15:57
<cite>После чего начал так ругаться?</cite>
История умалчивает.
3. Polos 02.04.25 16:23
Оригинальный дамп в епромку перезаливали?
4. kgbeast 02.04.25 16:40
Судя по этому
<i>Task : JMT0
Cause : pstFJCB->stExtraNumInfo.pubDialMemPtr @(FJMFaxMemory_InitiateFaxDial, 1196)</i>
Проблема начальной настройки функции факса. Попробуйте зайти в сервис и сделать Memory Clear.
Menu > # > 1 > 9 > 3 > 4
Data Setup -> Clear All Mem.
5. kochevnickus 02.04.25 16:46
<cite>Проблема начальной настройки функции факса. Попробуйте зайти в сервис и сделать Memory Clear.
Data Setup -> Clear All Mem.</cite>
Никаких манипуляций пока не проводил кроме подключения через дебаг, решил знающих спросить, да и в прошлом посте автор пробовал прошивать.
<cite>Оригинальный дамп в епромку перезаливали?</cite>
аппарат не дает зайти в настройки т.к. идет циклическая перезагрузка
6. kgbeast 02.04.25 16:59
<cite><b>kochevnickus</b> (5): аппарат не дает зайти в настройки т.к. идет циклическая перезагрузка</cite>
Тогда лучше скачать оригинальную прошивку, отрезать заголовок (в прошивке MFP137series_4nOne_V3.82.01.19_DS.hd это первые 506 байт) и прошить новую spi-флеш.
7. Felix 02.04.25 17:24
(5) Если у Вас есть программатор, то у меня есть "нулёвые" дампы от Flash 25Q128 и EEPROM 24C64 17-й версии FW.
https://disk.yandex.ru/d/m2-BcKBHi6lfAA
Только серийник привести в соответствие.
Отредактировано 17:33 02.04.25 Felix
8. Polos 02.04.25 17:40
блин. чет затупил, в (3) конечно же про флешку надо было писать
9. kochevnickus 02.04.25 18:20
Лежала в закромах фикс прошивка v3.82.1.10f. Прошил ей, аппарат завелся, но стал выдавать ошибку #S6-3210. Что-то не нравится в модуле WI-Fi
10. kochevnickus 02.04.25 19:02
<cite>(5) Если у Вас есть программатор, то у меня есть "нулёвые" дампы от Flash 25Q128 и EEPROM 24C64 17-й версии FW.</cite>
С этой прошивкой так же ошибка #S6-3210
Отредактировано 19:05 02.04.25 kochevnickus
11. kgbeast 02.04.25 19:18
Вот такая же проблема https://testcopy.tech/viewtopic.php?t=2654
<code>Да походу сдул R23, не подскажете наминал</code>
<code>100 Ом</code>
<code>Спасибо Всем большое впаял резистор и все заработало</code>
12. kochevnickus 02.04.25 19:38
Проверил я этот резистор, да и всю обвязку(
